I get the following error when I use the I2C at the same time as the FPGA open reference.
How can I gain access to the FPGA if I cannot open the reference.
The I2C part works fine on its own and reads accelerometer and gyro info. Likewise the Open reference to the FPGA and invoke method works ok to read and write data to the FPGA - on its own. But not together.
So the error says I must close one of them - but I cannot because I need them both at the same time. I need to read the accelerometer data and send a control signal to the FPGA via the invoke method.
