06-15-2015 08:23 PM
Howdy all!
I am currently trying to use a camera to create a video written to a flash drive. Both the camera and flash drive are connected to a myRIO, and both work with the myRIO. I have as of yet been completely unsuccessful in creating anything at all.
I created my VI using the example Grab and Save to AVI and changed only the save location. Whenever I run the code, an error occurs after the IMAQ AVI2 Create function: error -1074396070. It simply states that "IMAQ Vision: Unsupported function."
My suspicion is that the myRIO does not support the functions for creating video since the program works fine on my laptop when I run without the myRIO. I've updated the drivers on the myRIO, but the issue remains.
If myRIO does not support Vision, is there another way I can save video using the myRIO?
Any help would be greatly appreciated!
Thanks!
-Aggieimperator
06-16-2015 04:51 PM
This thread is a duplicate, and can also be found here:
http://forums.ni.com/t5/Machine-Vision/error-1074396070/m-p/3150167
Please refrain from creating multiple posts for the same issue.
06-16-2015 05:56 PM
My previous issue was solved permitting the program to save files. This new issue is, I believe is linked to the myRIO instead which is the purpose of my post on this board.
The goal is to save the video to a flash drive, not the local disk. When the progam is ultimately used, my computer will not be connected the myRIO to save the data and the local disk drive on the myRIO will not have enough room.
06-17-2015 08:40 AM
If you probe the output from build path, what do you see? I suspect that you're building your path incorrectly. If you hard-code an absolute path like "U:\temp.avi into "create AVI2" do you get this same issue?
06-17-2015 01:24 PM
Thanks for your suggestion!
I probed the build path and it created the path correctly "/U/test.avi". Following your suggestion, I hard-coded the path to "U:\temp.avi" and the path was correctly built. Unfortunately the same error remained right after IMAQ AVI2 Create.
06-17-2015 02:14 PM
Also, just out of curiosity, I tested another Labview example program to test my suspicion that the myRIO can't work with the AVI related function, and the same error occured.
I tested the AVI Codec Comparision VI and after the first AVI function, the error appeared.
I believe I have all the relavent software installed on the myRIO.
Attached is the example code (only alteration is the pathfile is switched to the flash drive on the myRIO) and view of all my installed software on the myRIO.
06-18-2015 08:02 AM
Do you happen to know which model you have? Is it the 1900 or the 1950?
06-18-2015 09:58 AM
I have the 1900 model.
06-19-2015 04:46 PM
Okay, I checked out a 1900 and I also couldn't get the AVI functions to work. I suspect that they aren't supported by the myRIO. Could you instead save the images to the flash drive and convert them to an AVI afterwards?
-Tanner
06-19-2015 05:39 PM
Thanks for all your help!
That'll work fine for the project.
It was original plan to just save images, but seeing the video option I figured I'd give it a try. I was just concerned that I was doing something wrong with the code or hadn't downloaded the correct software.
Well, thanks again for the support; I really appreciated it.
-AggieImperator
