01-27-2015 12:58 PM
Hi everyone,
I have just got my myRIO and I have been trying to connect it to the computer ever since But I am not able to connect it.
My Computer is: Core i7, windows 7 64 bit,
Kindly guide.
01-27-2015 01:34 PM
Did you use the USB cable that came with the unit. (I heard that some older USB cables won't work right.)
Do you have admin privilieges on your PC?
Are you running any unusual antivirus or other security software?
01-27-2015 07:47 PM
Does that SN match the one for the myRIO you have? If so, it's reading it at least for that point.
If you open MAX, do you see anything under Remote Devices?
01-27-2015 07:55 PM
02-01-2015 11:55 AM
That's strange. If it's showing up under Remote Systems, that means it's being seen. What happens if you hit Refresh on the other screen telling you it can't find the myRIO?
02-02-2015 11:40 AM
I actually had a similar issues the first time I hooked up myRIO. I think it fixed itself after I ran the USB monitor as administrator once but I don't remember the details. Worth a try. (close it, then right-click...run as administrator). It really made no sense at the time.
02-02-2015 12:37 PM
I ll try that.
But for now, I installed it on my personal machine and it worked like a charm!
03-11-2015 08:51 AM
I had this problem too. In my case the firewall in Symantec Endpoint Protection had activated itself and blocked communication.
05-04-2017 06:07 AM
I am having the same issue as above.
How do I run it as administrator? I can't find the .exe file for the myRIO USB Monitor.
05-05-2017 09:56 AM
Hi mr108,
Since the above thread hasn't seen any activity in two years, it might be best to create a new thread with your problem statement (and maybe more context into your myRIO/computer setup -- which myRIO are you using? OS? Firewalls active? RIO driver installed? etc.)
Nick
