03-23-2015 08:29 PM
I've been trying to use LabView/myRIO to send gps location to my phone via sms message. The VIs work seperately, but when I combine them, the VI that sends the email has an error within smtp open handle.VI. I've tried both having the GPS VI as a subVI and the messaging VI as the subVI both produce the same error. The GPS used is Digilent PmodGPS receiver.
Anybody experienced the same issue of not being able to send email through myRIO?
03-24-2015 04:45 PM
Hey there, that's a pretty neat little program you've got there. What what error message are you getting with the SMTP Open Handle? Is there an error number?
03-24-2015 09:59 PM - edited 03-24-2015 10:00 PM
When I drop the GPS into the text message VI I get "error - 63192 occurred @niLvFpga_Open_myRIO-1900.vi"
When I drop the text message into the GPS VI I get "Error 7 at call library function node in LabVIEWSMTPClient.lvlib: OpenHandle.vi: 102001 -> Text message.Vi -> main vi"
The original GPS VI was obtained from https://www.youtube.com/watch?
03-25-2015 03:48 PM
Hmm it sounds like you have some problems with references to files/the myRIO. Could you post a screenshot of your LabVIEW Project?
03-26-2015 07:01 PM
Here is an image of how oyur project is currently structured, there are several other VIs shown that we aren't using for this exact process so I've highlied the ones of interest.
03-27-2015 09:07 AM
So if you have the text message vi under the computer target, when you add it to the Main.vi on the myRIO target, it is likely not loading all the dependencies onto the myRIO. Move the text message vi under the myRIO and try it again.
03-27-2015 04:37 PM
You should double check and make sure you have the SMTP functionality installed on the myRIO as well. The Installing Software on NI myRIO article gives general instrcutions for opening the Add/Remove Software wizard for the myRIO. This 3rd party site also gives some screenshots.
03-30-2015 06:43 PM
After moving the text message VI under the myRIO, I still receive the "Error 7 at call library function node in LabVIEWSMTPClient.lvlib: OpenHandle.vi: 102001 -> Text message.Vi -> main vi message upon running the vi."
Any ideas on how to fix this error?
03-31-2015 06:15 PM
Do you have the SMTP Client installed on the myRIO? Go to Add/Remove Software on the myRIO in MAX, choose custom installation, and check to see if the following is installed
