09-02-2014 08:52 AM
is it possible to use ChipScope Debugging tool (following this guide: http://www.ni.com/white-paper/10499/en/ ) with a myRIO? This guide says that the requirements are:
A LabVIEW FPGA hardware target with 3 available high-speed TTL digital inputs and 1 available high-speed TTL digital output. These DIO pins should be capable of passing >1MHz signals. Here are some example target devices that you could use.
If so, how?
09-09-2014 10:31 AM
Hi Andrea,
I think that shouldnt' work for myRIO, since to program this product you use the NI-myRIO drivers and not the LV-FPGA Module.
Bye
