myDaq no power out
I have just purchased a myDaq. It seems to be functioning. For example, I can use the DMM to measure voltages. However, I have securely attached the terminal connector but have no voltage output on any pin.
Am I missing something simple?
(4,483 Views)
Is there no voltage across the 5V supply and digital ground (pins next to each other at the top of the device)?
http://www.ni.com/pdf/manuals/373060f.pdf
(4,453 Views)
Happily - problem solved.  The connector strip was at fault.  Now getting proper voltages accross all pins.
;Thanks,
Ray
(4,440 Views)
