02-26-2012 03:24 PM
although my myDAQ appears in the Windows device manager without exclamation marks and the blue LED lights up, the myDAQ does not appear in MAX and I am not able to use it.
Starting up NI myDAQ Troubleshooting Utility yields the following strange error message:
Device Drivers Installed (Failed)
- Using DAQmx Driver Version 9.3.5f2 . Please upgrade to version 9.1.1 or higher before using the myDAQ device. (Critical Failure)
- Using ELVISmx Driver Version 4.3.89.0. Driver version exceeds requirement.
Any idea what's going on there?
Christian
02-28-2012 02:51 AM
Hi Christian,
I would recommend you to UPgrade to the latest driver version 9.5.
That should hopefully solve the problem.
Cheers, RMathews
02-29-2012 03:23 AM
Thanx a lot - installing the update did solve my problem!! But 1.4 GB download for driver update ... phew! ... you do need a fast internet connection when working with NI products ...
Cheers,
Christian
