02-14-2014 08:55 AM
I am looking into purchasing a myDAQ, as we use LabVIEW at school and my job. I noticed the frequency generator only goes up to 20 kHz. Is this a limitation of the hardware or the student software? If it is merely a software limit, would the full version circumvent this limitation? I am interested in producing frequencies of at least 50-100 kHz.
02-17-2014 09:21 AM
Hey bentwookiee,
The myDAQ analog output hardware is capable of outputting 200 kS/s per channel. Depending on the type of signal you want to generate the maximum output frequency will be something less than that, and I think the pre-built FGEN code supports a maximum frequency to 20KHz to ensure enough samples per period to generate a good signal.
Thanks!
-Sam K
Join / Follow the LabVIEW Hacker Group on google+
