Hi i want to use a kinect sensor v1 with myrio fpga so that i can do some computatinaly expensive visual odometry and SLAM based applications.Is it possible to work on kinect using the MYRIO fpga?And can the fpga support such high processing tasks?
will is be a better option to work directly on the myrio cpu rather than its fpga?The ram of myrio is very low 512 mb.And standard 3d algos such as the kinect require vey high processing power.So pls tell me which is the best option fpga or cpu of myrio And will myrio as a whole be able to support what i am demanding?
