03-24-2015 06:26 AM
I'm trying to implement the PING))) sensor with the myRIO in labview.
In the robotics toolkit there are vi:s for implementing the PING))) sensor. The problem is I don't understand how these work.
First of all, I find these under robotics->Sense/Act->I/O with sim->Sonar->Parallax PING))). It is also possible to find the read PING))) under the starter kit menu. However, both these require an initialisation. And I don't know how to implement these and I can't find any help on the initialisation either.
Has anyone done this? How do I do it?
If it is not possible to implement it this way, how can I implement it manually? I found one solution online - however I couldn't open that properly which made it hard to understand.
Thanks!
03-26-2015 10:10 AM - edited 03-26-2015 10:18 AM
Hello izredam,
Can you share what your current code exactly looks like?
Which online solution did you find?
Is it this one?
https://decibel.ni.com/content/docs/DOC-30452
Why are you not able to open it succesfully?
Which messages do you get?
