03-23-2015 08:11 AM
I want to use the I2C myRio. To make things easier, I'm currently working on the integration of MCP9808 a simple Thermometer.
I guess i created the easiest I2C-VI you can imagine an it doesn't work. It would be nice if you woul have look at it.
The address is 19. I connected A0 to the 3V.
Solved! Go to Solution.
03-23-2015 08:13 AM
Adding attachments
03-24-2015 02:15 AM
After i changed the slave adress to hex there is no failure code anymore. Now i want to read out the actual data.
Anybody a idea how to do that?
03-26-2015 06:59 AM
Nice i Solved my problem by my self 😃
It`s not really finished and there a probably some things to optimise but it works.
03-26-2015 07:01 AM
