04-11-2017 01:13 PM
hi..
we are using a student version of labview .In that only two features have got license(labview development system and application builder).
actually we are trying to dump a VI file which we have developed for text to speech conversion on to myrio board and play the audio output.So please let us know about the software tools required , the interface procedure ,configuration of audio out of myrio board.
Thanks in advance...
04-11-2017 09:50 PM
For required software, you'll need LabVIEW, the Real Time Module, and the myRIO Toolkit.
http://www.ni.com/product-documentation/14603/en/
Basically just add the myRIO to your LabVIEW project (http://zone.ni.com/reference/en-XX/help/370622K-01/lvrthowto/addingrttargets_lvproject/) add a new VI under the target, and then whenever you run the VI it will deploy code and run it on the myRIO. You can pretty easily interact with the I/O using the express VIs which you will see after adding the device to your target. I would recommend taking a look at some of the example code like the link shows.
