05-09-2017 03:19 PM
The sound sample vi file opened without any errors. But the ring creator vi doesn't. It asks to find the file name "myrio V1.1 fpga throughput.lvbitx"
05-09-2017 03:49 PM
That file should be installed on your computer. I would check if you have the required software installed for the myRIO. They are listed here: http://www.ni.com/product-documentation/14603/en/
I was able to find the file in this path: C:\Program Files (x86)\National Instruments\LabVIEW<version>\vi.lib\myRIO\FPGA\bitfiles
Angela L.
05-10-2017 12:38 AM
Since my project is not an fpga project, I don't need that file anyway. I want to do it as a normal myrio project. So that file wouldn't be necessary.
11-09-2017 08:44 AM
Hi there,
How come even though i change the sound file i read in, then replace the new array in the 'ring creator' i still get the same tune and not my update one? very confusing.
My idea was the i would feed in a new .wav file and within the sound sample, bring that new array to the myrio on the Ring Creator by replacing the array. But whatever i have in my array plays the default tune and not my new one?
Any ideas?
Watter
11-10-2017 09:20 AM
Watter,
Are you sure you're copying in the array correctly? You may want to try Edit --> "Reinitialize values to default" to ensure the old sound file is cleared from the array.
Brian P.
