12-09-2013 02:33 AM
hi everybody my supervisor requires me to use the NI myDAQ and he ask me to create an external circuit in order that I may accquire data using the map and the circuit I want to know the contents of this circuit and the appropriate VI!! help please
12-09-2013 08:29 AM
Hey,
Start with the HIH-4000-001 data sheet, it has all the info you need: http://sensing.honeywell.com/honeywell-sensing-hih4000%20series-product-sheet-009017-5-en.pdf?name=H...
The sensor has 3 pins, power, ground and out. Out is an analog voltage which represents the humidity using the following equation found on page 2 of the data sheet:
VOUT=(VSUPPLY)(0.0062(sensor RH) + 0.16), typical at 25 ºC
Page 5 of the datasheet recommends the following 'typical application circuit'.
Take some time and look through the data sheet. All of the information you need is there (that's the point of a data sheet). Datasheets can be intimidating at first but once you learn how to read them you'll be able to use any sensor you can find.
-Sam K
Join / Follow the LabVIEW Hacker Group on google+
12-09-2013 03:44 PM
thank you very much for help 🙂
05-08-2016 10:55 AM
hi.. i'm also using this sensor, but i can't get the humidity number exactly, can you give me the vi you use?
what NI module do you use anyway? i'm using NI9201, is it possible?
