fpga
Hey fellas,
I'm trying to read a temperature sensor data using the FPGA and I was able to do that, but at the same time I want to use other digital and analog IO on the myrio without the fpga but so far I can only do one of them at a time, because the myrio IO vi's only works on the default FPGA personality, is there anyway I can overcome this?
(4,689 Views)
Mesopotamia,
Have you tried modifying the default FPGA personality? As long as you don't change the I/O with which you want to use the I/O VIs, you should be able to add custom code.
(4,667 Views)
Thank you for your reply, I got to work now. I didn't know once I modify the FPGA I won't be able to use those VIs anymore inside the main vi, I was trying to avoid modifying the FPGA file so I don't need to deal with rebuilding the file, but eventually I had to
(4,663 Views)
