06-23-2014 07:08 PM
I am using cRIO-9024 and I have built my VI using control andsimuation module (including transfer function models).
I am using Analog Output NI 9263 which is also connected to my oscilloscope and I want to display the output values on the scope in real time.
My step size is 0.0001s (10^-4 s)
What timing parameter ie timing source and period should I set so that I will get real time output?
I am confused between 1MHz and Synchronize to Scan Engine options
Please reply
Thanks in advance
06-24-2014 03:47 PM
Hey Ashish,
You won't be able to use the scan engine with your application. You'll need to look into the read/write controls using a fpga reference.
You can find an example by opening up the example finder from Help>>Find Examples. From there on the browse tab select the directory structure and navigate to CompactRIO>>Module Specific>>NI 9265
Open the NI 9265 Getting Started.lvproj,
Open the project and change the 9265 to a 9263 and use your control code with the read/write node.
Please let me know if you have any questions.
Thank you,
