06-10-2017 12:08 AM
I am using a project (see zip file) wrote using LabVIEW myRIO-2015 for the IMU sensor MPU9250. The computer that I am using has LabVIEW myRIO-2016 installed. It also has FPGA, Real time modules and drivers.
When I run the FPGA program (FPGA_MPU_rev1), it compiles properly and works fine.. But when I run the real time program (RT_MPU9250_main_rev1), I am asked to save the changes (figure1). After I choose save, the program runs fine for 128 iterations and then I loose the connection to the myRIO target (figure2). I choose Ok and run the program again. I get the conflict resolution error (figure 3 and 4). After I choose Apply, the program runs for 128 iteration and looses the connection again.
I used a different myRIO to check if its the hardware issue. But I still have the above mentioned errors. I even tried repairing the RT module using NI-MAX, but it did not help.
The program seems to work with a different laptop which uses LabVIEW myRIO-2015 software.
Can anyone explain what is wrong here?
