03-20-2012 09:26 AM
If i buy the following, what are the accesories that comes with it? If I have to purchase it separately, what is the specific accesory for the particular device. Thank you.
CRIO-9075 Integrated 1
Controller and Chassis
System, 400 MHz PowerPC
controller, LX 25 Gate FPGA,
4-slots.
NI 9201 8-Channel, 12-Bit, + 1
/-10 VDC, 500 kS/s, Analog
Input Module
NI 9474 8-Channel 24 V, 1 1
us, High-Speed Sourcing
Digital Output Module
03-20-2012 10:26 AM - last edited on 01-25-2024 04:42 PM by migration-bot
Hi Chire,
A direct answer = no accesories ship with the hardware you listed below.
NI has a wide selection of accesories for cRIO. Depending on what kind of application you are working on, oyu may not need any accesories or you may need all of them. Feel free to email me if you can share details or want help picking out what you need...
cRIO 9075:
Power Supplies = https://www.ni.com/en-us/shop/category/power-accessories.html?productId=118335
Mounting Kits
NI 9971 Backshell for 2-pos connector block (qty 4)... these are the little black power connectors on the cRIO Chassis (in case the orginal ones are lost)
Industrial Enclosures for CompactRIO = https://www.ni.com/en-us/support/model.ni-9918.html
cRIO HMI = https://www.ni.com/en-us/shop/category/hmis-and-displays.html
9201 => we offer 2 different connectivity options... Screw Terminal & D-Sub... each connectivity option has different accessories
9474 => has Screw Terminals built on it for connectivity. We also offer a Strain relief backshell as anaccesory
I hope this helps.
Cheers,
Jason Dawson
NI - California Academic Sales
