Web messaging app for NI myRIO
Hi, i have started working on web messaging application for NI myRIO. I have a query on DOC-37204. in that it is mentioned that , we are required to paste service token into front panel and into rt main vi too. But where is the sample VI given? i didnt see any sample project on website also. please sort out this issue as soon as possible.
(8,639 Views)
Hi AjinkyaM,
A Web Messaging account is required to run this demo. Sign up for an account at http://myRIO.niwsc.com
then you can download demo http://screencast.com/t/6MuatcUxlFv
CaravagGIO
(8,630 Views)
Hi, i already have an account. I downloaded both post msg vi and error msg vi, moreover i have add-ons also. Can you give me the attachment of the vi if possible. please
(8,626 Views)
Hi, create new project in LabView @nd select "Web Messaging for NI myRIO" Sample Project.
CaravagGIO
(8,611 Views)
i am getting following error now in rt vi.....
Call Library Function Node in LabVIEWHTTPClient.lvlib:OpenHandle.vi:6450001->Web Messaging API.lvlib:Post Message.vi->RT Main.vi
(8,602 Views)
What is the error code? If it is error 7, maybe HTTP client is missing and you should install it to myRIO . You can do it using MAX>>Remote Systems>>myRIO>>Software>>Add/Remove. If you are not sure which software you will need select all of the Web features 😉
Please let me know if it works.
CaravagGIO
(8,474 Views)
Hey it worked. Thank you. But when i use web messaging in myRIO applications, myRIO functions or updates it data very slow as before. Why is it happening so ?
(8,459 Views)
