Using digital IO on Elvis II+ with Matlab?
I'm wondering, if there is a way to use digital IO ports using Matlab. http://www.mathworks.com/products/daq/supportedio14005.html says there is support for Data Acquisition Toolbox. I'm successfully using the session-based interface (only for analog IO), but digital IO is working only on legacy-based interface. Can you, please, tell me, what version of device drivers (NI-DAQ) is appropriate?
Thanks and have a nice day
Martin Cala
(5,734 Views)
The latest version of NI DAQ is 7.4.4, you can download from here http://joule.ni.com/nidu/cds/view/p/id/570/lang/en
Also, you can transfer your code in LabVIEW and use Mathscript Node, it will be easier to use DAQmx and connect to real I/Os
You can read more information about Mathscript Node here http://zone.ni.com/reference/en-XX/help/371361H-01/gmath/mathscript_node/
Kind regards,
Ion R.
(5,725 Views)
