Solar Tracking
i have final project to make solar tracking. Can you help me to teach me use ni myrio-1900 and Labview with another sensor like Light Dependent Resistor(LDR). In my project, the solar traking will working if the LDR receives light from sun. And it will give a signal to dc motor to make solar tracking working.
thank you for your attention, i hope you can help me.
(3,434 Views)
Accepted by topic author ditorahmataulia
The project you are looking to do is extremely specific, so there is not much we can fully help you on. However, if you would like to move forward, I recommend checking what kind of signals you need to read in from your solar sensor, and what kind of signals you need to output to control the motor.
From there we have help to send and receive analog and digital signals, linked below.
NI myRIO Getting Started
http://www.ni.com/myrio/setup/getting-started/
Best,
Shamik C
http://www.ni.com/support
(3,401 Views)
Hello ShamWOW, can you give me any example of labview's program for my problem (the solar tracking that i explain before)?
Btw i need to read analog signal  from my solar sensor (LDR) and digital signal for output to control the motor.
Thanks for your help.
(3,377 Views)
