11-19-2016 05:04 PM
Is it possible to set the threshold values for digital inputs within the myDAQ?
Solved! Go to Solution.
11-21-2016 05:12 PM
Hi Maltodextrin,
Do you mean is it possible to set the voltage level at which a signal will be measured as high or low?
If this is what you mean, the answer is no. These values are determined by the hardware, and adhere to the TTL +5V standard. See this article for further information on the TTL signals, and what voltage range will result in a high or low value reading.
11-22-2016 11:05 AM
Thank you so much, this is exactly what I was looking for!
