03-24-2011 04:13 PM
Hello I want to give a simple demo on SFSK for PLC(Power line Communication) using NI myDAQ to students.
Can this be done? I also have a cRIO but I would rather use the myDAQ to generate SFSK modulation and demodulation.
03-25-2011 12:05 PM
ut perg,
To be honest, I am not too familiar with SFSK for PLC, but I would look at the following FSK example. I ran it connected to a myDAQ, and it did not cause any errors.
http://decibel.ni.com/content/docs/DOC-6575
Drew T.
03-31-2011 11:28 PM
Hi I found this example
http://decibel.ni.com/content/docs/DOC-12604
and was wondering if a similar demo can be done with FSK on a myDAQ.
04-01-2011 12:11 AM
I got the modulator(BFSK) to work.
Could you help with the demodulator part?
It's using the ASK demo refered above
04-04-2011 11:08 AM
Hi there,
Do you have the Modulation Toolkit for LabVIEW?
If not we may still be able to get this example up and running for you.
What changes have you made to that example so far?
04-04-2011 11:21 AM
I can download the modulation toolkit from the university website
but I would like to try it without the toolkit since the myDAQ's HW performance is not as high as a PXI .
I modified the ASK example to have the frequency change for either a 0 or 1 bit stream on the modulator side which I uploaded on my previous post.
If you could help with the demodulator side it would be a great help for the students I'm trying to demonstrate to.
Also get them really motivated to use myDAQ in their studies.
04-04-2011 11:32 AM
Here is the modulator
04-05-2011 11:50 AM
04-11-2011 10:16 PM
04-12-2011 10:44 AM
I am trying to use the toolkit but can't get it to work.
Please help~~
