01-24-2012 08:20 PM
Hi everyone,
I am using LabVIEW FPGA board. I tried to use rotary button on the board but I can't find the ROT CENTER (or ROT A, ROT B) in the New FPGA I/O. Please help me indicate the problem.
Thank you so much
Mina
01-25-2012 01:33 PM
Hi Mina,
What versions of LabVIEW and the Digital Electronics FPGA Board Driver are you using? If possible can you provide screenshots of your project and the New FPGA I/O window?
Tim W.
Applications Engineering
01-25-2012 07:30 PM - edited 01-25-2012 07:31 PM
Thank you so much because of cosidering,
I am using NI Digital Electronics FPGA Board follow the link below and LabVIEW 2010
http://zone.ni.com/devzone/cda/pub/p/id/763
Morever I attached the screenshot New FPGA I/O, I didn't see the ROT appear
Please help me solve this problem
Thank you so much
01-26-2012 01:36 PM
First, make sure you've got the specific driver for that board. If you're trying to get this example up and running (since it refers to ROT A, B and Center) I can see that it was written for a slightly different board (the Digilent S3E Board) that has direct I/O for channels named ROT_A, B, and Center for a built-in encoder knob. For the NI Digital Electronics FPGA Board there are a couple things to know. First, the rotary knob on the board itself is not an encoder as described on page 2-11 of the user's manual. Rather, it is a control for a clock output and is not connected to the FPGA at all. There is a hardware add-on module from Digilent called the PmodENC Rotary Encoder Module that can plug in to the PMOD port on the NI board. If this device is plugged in to PMOD1 (aka J1 in the project) you can access its I/O lines in your project by going to New>>FPGA I/O>>Pmod Connectors>>J1:1-4 or J1:7-10. Once you've added these to the project you can rename them to anything you like, such as ROT_A or ROT_B.
Tim W.
01-26-2012 07:17 PM
Hi Tim W,
Frankly I tried to follow this example. Now I understand this problem. Thank you so much for your help
Mina
