03-19-2011 04:55 AM
I am trying to do analog edge triggering on an analog output, but whenever I try to add a triggering block it throws error -200077, and tells me...
Property: Ref.TrigType
You Have Requested: Analog Edge
You Can Select: None
I'm pretty sure that my hardware supports analog triggering because I can trigger in the pre-compiled NI ELVISmx tools.
Any ideas?
03-21-2011 10:57 AM - edited 03-21-2011 11:02 AM
Hello 🙂
Just to clarify, are you attempting to trigger the device based on an output from the device?
03-21-2011 11:02 AM
myDAQ does not support analog triggering in HW, so the ELVISmx software does it by using a continuously-acquiring task. For some reason it didn't get ported to the express block. Luckily someone did this for you.
03-21-2011 07:29 PM
gaving: Thanks! I'll take a look at those VIs
James 😧 Actually I did want to trigger on an analog output but I thought it would be easier to generate a trigger output which is read by an analog input and trigger on that (since I thought the myDAQ had analog trigger capabilities). Since I need to implement custom triggering code anyway, do you know if the myDAQ has access to ao/StartTrigger?
