Problem with stored Data from DAQ 6008
I make a student project in which I have to record one data every 10 minutes from a DAQ 6008 and send them to excel, the problem is that the document in which I keep stored more data over a minute. I dontknow where I put the delay. Does anyone could help me?
This is my Diagram:
(5,721 Views)
You can use the Timing Tools from the Function pallette: Wait, Wait Until Next Ms and Time Delay Express VI.  You can place this functions inside the while loop, which will execute every specific amount of miliseconds.
Regards!
Anuar Rojas
Anuar R.
National Instruments México y Latinoamérica
Ingeniería de Aplicaciones
www.ni.com/soporte
(5,718 Views)
Ok , dont problem in the delay , the promblem is the document .txt have a lot of numbers.
(5,707 Views)
But you are adding only one value every 10 minutes to the *.txt document right?
From what I understood the first time, you are acquiring only 1 value from the USB 6008 every 10 minutes.  This value is added to a spreadsheet and displayed in a waveform chart and other indicators.  Am I right?
Anuar Rojas
Anuar R.
www.ni.com/soporte
(5,694 Views)
