05-18-2013 07:21 PM
Hello everyone,
I'm using high speed digitizer (NI 5922). I installed the Labview 8.5.1, then the NI scope software for the NI 5922 High speed digitizer, and then the driver hardware. And I tested the DAQmx with the MAX and it passes the self test. But when I started to use the labview with the DAQ assistant as described in the manuals I didn't find any supported devices! Should I connect a physical device to the channels of the driver hardware or what should I do?
Ibrahim
Solved! Go to Solution.
05-20-2013 05:34 PM
The 5922 is supported by NI-Scope http://www.ni.com/digitizers/software.htm and not by DAQmx. That page should help you get started.
05-21-2013 03:05 AM
Hey Ibrahim,
you can't use the DAQ Assistant to use your NI-5922. The DAQ Assistant works only with DAQmx devices and the NI-5922 doesn't use the DAQmx driver.
You can use the so called Soft Front Panel to test your device. Take a look at this page:
NIScopeTutorial.pdf
http://classes.engineering.wustl.edu/ese103/images/7/7b/NIScopeTutorial.pdf
If you want tot programm the Scope with VIs, the following page is a good starting point:
Getting Started with NI-SCOPE - Developer Zone - National Instruments
http://www.ni.com/white-paper/3382/en
Regards, Stephan
05-27-2013 09:00 AM - edited 05-27-2013 09:07 AM
Hi Gaving and Stephan,
Thank you for your kind concern,
I think I was using the wrong program. anyway, for some reasons I reinstalled the NI-Scope again. Now, I'm trying to program the NI-scope with the LabView but I can't find the NI-scope driver in Instrument drivers of the Labview block diagram.
As mentioned in the help:
In the block diagram>>express palette >>input>> then to the instrument driver!
for some reasons, I don't know why, I cannot find the initialize function of the NI-scope driver Although, it is listed in the MAX and passed the self test and I can use the SCOPE soft front panel interactively!
what should I do?
Also, I can't open the examples in the NI-scope itself ( start>>programs>>National instruments>>NI-Scope>> examples>>C>>I see folders each one contains three files; one txt and the other with (.c) extension and the third one I don't know its type, Is this normal?
best,
Ibrahim
05-27-2013 09:03 AM - edited 05-27-2013 09:09 AM
what should I do?
Also, I can't open the examples in the NI-scope itself ( start>>programs>>National instruments>>NI-Scope>> examples>>C>>I see folders each one contains three files; one txt and the other with (.c) extension and the third one I don't know it's type, Is this normal?
best,
Ibrahim
05-29-2013 09:43 AM
The LabVIEW examples should have been installed in the LabVIEW directory (like c:\program files\national instruments\labview\examples\). You can also get to them through the help menu>>find examples>>hardware input and output.
05-29-2013 09:53 AM
Hi Gaving,
I reallz appreciate zour help,
I still have another problem with mz NI-Scope cos I cant see the its initialize function in the block diagram. the driver is not visible.
it passed the self test in the MAX but I cant see its icon in the block instrument and driver pallete of the block diagram!
best,
Ibrahim
05-29-2013 10:02 AM
hmm...let me throw out some possible explanations
05-29-2013 10:57 AM
mmm!!
Really, I installed the labView first! and I'm using 8.5.1 which is compatible with my NI-Scope 4.0 driver! even more I just re-installed the NI-scope again and I still can't see the icon of the NI-Scope
05-29-2013 11:07 AM
I'm running out of ideas...try discussing this in the http://forums.ni.com/t5/High-Speed-Digitizers/bd-p/150 forum since it is more specialized for scopes.
