NI myDAQ driver on MAX
How can I annex NI myDAQ driver? It is Not included in the list of drivers created when I installed NI-DAQmx. My operating system is Windows 7 Vista.
Thanks.
Diego.
(5,734 Views)
The NI-DAQmx driver installs support for the NI myDAQ to be used with the NI-DAQmx API in LabVIEW and provides support in MAX for creating DAQmx tasks/channels using the NI myDAQ. However, to get the NI ELVIS II/II+/myDAQ-specific express VIs and soft front panels, you will need to install the NI ELVISmx driver.
Donovan
(5,706 Views)
Hello diegote,
NI myDAQ Requires NI ELVISmx and NI DAQmx. You can check this link for additional information:
NI myDAQ Driver Download
http://www.ni.com/white-paper/12403/en/#toc1
If you have any trouble this troubleshooting link coul help you:
NI myDAQ Troubleshooting Utility
http://www.ni.com/white-paper/11424/en/
Let us know if this information helped you. Kind regards.
David P.
www.ni.com/soporte
(5,670 Views)
