11-17-2012 04:59 PM
I have been having alot of trouble with my myDAQ. I installed the software and the computer recognizes the myDAQ, however, whenever I run a program through ELVIS (DMM FGEN etc), under device it says, "No Supported Devices." The myDAQ drivers are also downloaded. I have a Windows 7 also. I also tried uninstalling and reinstalling the software and that did not work either. Any help would be greaatly appreciated.
Benjamin
11-19-2012 09:25 AM
I'm sorry you are having trouble, Benjamin.
There is a program that installs with the myDAQ driver (NI-DAQmx) which should be linked on your desktop or your start menu. It is called "Measurement and Automation Explorer" (or NI MAX)
If you can open that, click to the left of "Devices and Interfaces" to expand it and see if your myDAQ shows up there.
Also, follow these instructions to create a "Technical Support Report" and post it here so we can know more about the software you have installed.
Hopefully we can get you up and running soon 🙂
-gavin
07-23-2013 05:19 AM
09-11-2013 03:50 PM
I'm having the same problem. NIMAX is recognizing my myDAQ but they are not being recognized by my ELVIS instruments (digital multimeter or others).
09-12-2013 11:03 AM
Hello msingletary,
I saw your other topic and I can try to help you out in the other post.
12-05-2013 10:11 PM
12-06-2013 02:21 PM
Hello bassirou08,
This is a pretty old forum post, and it was about ELVIS recognizing myDAQ.
You might have better luck if you create a new forum topic and give a description of what you need help with. Thanks!
K. Johnson
Applications Engineer
04-14-2014 03:16 AM
This is very useful information shared here. I am really thankful for this.
