08-15-2013 02:26 PM
I was given this
http://sine.ni.com/nips/cds/view/p/lang/en/nid/1041
I am biology Major, where do I even start? I try to look at the data sheet and stuff I don't understand anything. Is there a tutorial somewhere?
08-15-2013 02:35 PM
Here's a resource to maybe help you get started: http://www.ni.com/white-paper/5612/en
I found that from http://www.ni.com/data-acquisition/what-is/
Feel free to ask us any questions as you get started with NI data acquisition hardware and software.
08-16-2013 10:13 PM
Hi is there a manual that will describe the hardward? I am not referring to how to build it, but what should be soldier up with what and how to operate it specfically with the board I have.
I search online most of the resource refer to the ni-daqmx a new model of what I have.
All I want to do is to read in a digital input and give out a digital output, it sound simple and it should be.
08-17-2013 01:36 AM - edited 08-17-2013 01:40 AM
Sorry let me clarify, I simply want to understand the document in this link "http://sine.ni.com/psp/app/doc/p/id/psp-42/lang/en" It gives abbreviations for the pins and I don't understand anything.
08-19-2013 10:10 AM
Okay, let's try this -
1. install DAQmx - http://joule.ni.com/nidu/cds/view/p/id/4240/lang/en It says that it only supports the PXI version of your card, but so does T-DAQ so it will probably work.
2. Open the program NI MAX on your computer and see if the 6070E shows up in the Hardware section. You can right click on it to checkout the device pinout.
3. Open an example. If you are using LabVIEW, in labview go to help->find examples...->Hardware Input and Output-> DAQmx-> then whatever type of measurement you want.
If you are using text based to programming. There is a textbased examples folder you can get to by going to start ->all programs->National Instruments->DAQmx then the text based stuff.
4. In the example select the device name that showed up in MAX and the correct pins from the pinout.
08-19-2013 10:23 AM
thanks
10-03-2013 12:27 PM
Hi, Do you know of any example where I can use matlab instead?
I just want to do somethign as simple as this in matlab
If detect digital input
print('output!')
else
print('no output')
and
Send digital output
done.
10-07-2013 05:48 AM
Here's a MATLAB example using Data Acquisition Toolbox:
http://www.mathworks.com/help/daq/acquire-non-clocked-digital-data-1.html
-Rob
