07-17-2017 05:57 AM
i was was researching on erasing files associated with real time projects on the myrio. I found topics on the FPGA going through and the fact that only one FPGA program can be install at a time but it seems like you can have multiple real time targets. When going into the directory of the myrio through the IP address I see where my real time target is at but it seems like it is installed at 3 locations (directory). Also there are a a lot of sub folders. My questions are:
1) is there a way to view all real time target programs installed, select and delete? Via MAX? Program?
2) if I went though the IP, do I delete all three of those real time target?
3) what the most efficient way to do a clean install. I.E., format and reinstall the standard system files on the myrio.
guilio
07-18-2017 09:44 AM
On the topic of formatting the myRIO, I found a previous forum post that lays out how to format and reinstall the system files to your myRIO.
(cRIO 9023 setting factory default)
07-19-2017 06:35 AM
I seen that article and figured that would be the formatting. I would just hate to have to go through that process each time I want to upload a new RT program. I know I don't have to, and I can store multiple RT projects but one thinking if the RT programs take up too much memory, then would there be a way to just delete the previous RT program. As mentioned, when I went through the directory, I seen it in 3 places.
07-20-2017 09:32 AM
Following
07-20-2017 09:40 AM
You could right click on the VI in the project, select undeploy, then check if the VI is still present in those three locations on the myRIO
07-20-2017 03:04 PM - edited 07-20-2017 03:22 PM
There is no undeploy in the drop down box.
I did erase 2 real time farther files and it erase it from all 3 directories. The issue though is my memory still isn't freeing up.
07-24-2017 07:39 AM - edited 07-24-2017 07:41 AM
I went ahead and did the format of the disk. After format, memory was free. It did not take long at all. However, I reinstalled the software and the memory went down which I learned that the software is install on the device. I always thought the software was stored on the computer and the myrio had hardcoded drivers/software for execution of the VI. What takes down the memory is the software and not so much the VIs that are downloaded.
Also, It seems like this go around, I apparently got more software installed on the device which took more memory. Some of the software I have no idea what it exactly does, or if I need it, but my question is now geared to if I need the software, will Labview let me know? For instance. I have the NI-IMAQdx software for USB, USB3 and IP Camera Support. I can take a guess on what these are for, but for now, I don't need them. If I added in a USB Camera, will Labview let me know I need to update the software?
TWK
07-25-2017 08:08 AM
LabVIEW would not directly let you know but if you're missing needed software, your device won't see the camera properly.
