06-15-2014 10:22 AM
Hello All
I am building an app with my local high school and I have noticed an issue with the USB subsystem with the myRIO
We are using a number of USB connected sensors. The system sees them all and can communicate with them fine.
If we unplug one sensor the system looses connection to all USB devices on the bus.
When we plug the sensor back in, the system can once again see all of the usb devises
If I ssh into the shell and execute the ls /dev/ttyUSB* command I can see multiple USB devices
Again if I unplug one device and execute the above command, the system reports back an error
I have looked into the mdev settings and things look like they should work there, but I am unable to understand why we loose all connections if only one device is unplugged
Thank you for any help any one can give
Dan
06-16-2014 09:01 AM
Dan,
I have a couple questions just so we can have more information.
Does it matter what device is unplugged? Have you tried unplugging different devices? Does the same behavior occue?
Do you see this same behavior on other computers?
Are you plugging your USB device in on the front of your computer or on the back?
What OS are you running? What specific hardware are you using?
Has this always happened or are you just now noticing it?
06-16-2014 09:19 AM
Hello
The sensor devices are connected to the myRIO via USB
The same behaviour occurs no matter what sensor device I unplug from the myRIO
I have tried unplugging different devices, in different orders, even different hubs, same thing
I will try to answer all of your questions
This is a high school project that started out life on a Raspberry Pi
We are in the process of upgrading the hardware to the NI myRIO
We will be using all of the same USB sensors, but we will be adding some Analog sensors in the future
Analogue to Digital is something that is not native to the Pi
The Pi does not have any issue with hotplugging of the USB sensors
The pi is running Raspian with a Linux kernel version of 3.6.11+
I am in the process of debugging the myRIO port, and I unplugged a sensor from the myRIO when all communications to the USB sensors was lost.
the uname -a command returns the following data
Linus NI-myRIO-1900-XXXXXXXX 3.25.35-rt52-1.0.0f1 #1 SMP PREEMPT RT Wed Jun 12 09:57:26 CDT 2013 armv71 GNU/Linux
I added the X's in place of my unit's serial number,let me know if this is needed
If you need any more information please let me know
Thank you for your help in this matter
Dan
06-17-2014 09:51 AM
Dan,
A couple more questions:
Do you see this behavior on any computer you plug the USB into?
What sensor devices are you using?
What ports are you plugging the sensors into?
06-17-2014 10:15 AM
Hello
I am connecting to sensors from Atlas Scientific (http://atlas-scientific.com)
However this happens even when I plug in a display device from Crystalfontz
This only happens on the myRIO
I am plugging a DLink hub into the USB port on the myRIO and then plugging in the devices into the hub
As I only have 1 myRIO I am unable to determine if this happens on all myRIOs or not
Can you run a test on your side to see if the same thing happens to you
Plug a USB hub into a myRIO
Plug a couple of USB devices into the hub
ssh into the myRIO and execute this command ls /dev/ttyUSB*
I get the following /dev/ttyUSB0 /dev/ttyUSB1 /dev/ttyUSB2 /dev/ttyUSB2
unplug one of the USB devices from the hub and re-execute the command ls /dev/ttyUSB*
I get the following output
ls: /dev/ttyUSB*: No such file or directory
When I plug in a USB device all USB devices will then show up
I have added debugging statements in the usb.sh script that is referenced from the mdev.conf file
But I am not knowadgeable enough to pinpoint the problem
I have a number of theories but I do not have tje skillset to correct the issue
I am hoping that you will be able to determine what is happining and determine a correction or work around
Thank You
Dan
06-18-2014 04:47 PM
Hey Dan,
What specific sensors are you using? I think there is a power surge happening when you unplug your sensors which is causing the issue. Once we look into the specifications of the sensors that you are using, we can look into see if it is a power issue.
06-19-2014 10:43 AM
Hello
I have taken away all of the sensors and pared down the system to the bare essentials
I am connecting the myRIO to a D-Link 7 port USB 2.0 hub
This hub then splits out to two USB to serial converters from Atlas-Scientific
Their data is located here, https://www.atlas-scientific.com/product_pages/embedded/debugger.html
These devices do not need any drivers installed onto the myRIO as they work out of the box
When I have both plugged in I ssh into the myRIO and execute the command ls /dev/ttyUSB*
I get back /dev/ttyUSB0 /dev/ttyUSB1
I unplug one of the devices and re-execute the comamand and I get the following error message
I plug back in the USB serial converter and both USB devices reappear in the /dev/ subdiractory
In your last answer you stated that there may be an electrical problem that is causing this issue
So I tried the following test
I plugged a third USB to serial converter into a second powered D-Link hub
I plugged this hub in to a USB isolator device from Phidgets http://www.phidgets.com/products.php?category=28&product_id=3060_0
And I plugged this device into the original powered D-Link USB hub
I executed the ls command on the myRIO device and I was presented with three /dev/ttyUSB entries
Then I unplugged the third USB to serial device, the one that is seperated from the myRIO by the USB isolation device and again checked the ls command. Once again all /dev/ttyUSB devices were gone.
I plugged in the third USB to serial device back into the second USB hub and re-ran the ls command
All three /dev/ttyUSB devices showed up.
Do you know what command to execute that would reinitialize the USB devices in the /dev subdirectory
in my Labview app I can shell out and execute the ls /dev/ttyUSB* command
Based on the data from this command I can then go about reading data or try to re-initialize the USB connections
I have tried to do this from the command line on the myRIO but with no luck as of yet.
Any help you can offer would be greatly appreciated
Dan
06-20-2014 02:40 PM
Hi dan6077,
Earlier in the thread you mentioned using 4 USB devices. In a more recent test, it sounds like you were using 2 USB devices. What steps did you take to move from 4 USB devices to 2 USB devices and get the ls command to return devices? Did restarting the myRIO after removing devices allow them all to show up? The /dev subdirectory should be reinitialized when the myRIO is reset. If you remove one of your USB devices, reset the myRIO, then try the ls command, do the devices show up?
Also, are you running any code on the myRIO while you are adding, removing, and checking the USB devices?
06-24-2014 03:20 PM
Hello Catherine B.
I performed the following steps with these results
Initial myRio Setup
USB host port connected to a 7 port USB 2.0 D-Link hub
Three USB to serial boards connected to the D-Link hub
These are simple USB to serial converters which work with no drivers needing installation
1) Created a new project - Motion Sensor Example
2) Pushed it to the myRIO and confirmed it was working
This means we have no communications going on within the myRIO
3) ssh'd onto the device as the admin
4) Executed the ls /dev/ttyUSB* command
5) Confirmed the connection of three USB devices
6) Unplugged one of the USB devices3
7) Executed the ls /dev/ttyUSB* command
😎 Confirmed loss of connection to all USB devices in /dev/
9) Executed the reboot command
10) Re-established the ssh connection to the myRIO
11) Executed the ls /dev/ttyUSB* command
12) Confirmed that there were two ttyUSB connections
You are correct in stateing that the /dev subdirectory gets reinitialized after a reboot
I have also confirmed that if I plug a USB device into the myRIO the /dev subdirectory gets populated with all the ttyUSB devices connected to the system.
What I am bringing to your attention is that the myRIO loses all connection to the USB bus when a single device is unplugged.
I am trying to determine if this is planned or unplanned behaviour for the myRIO, I only have one unit at the moment so I cannot test on other units
As this is not the behaviour that I have experienced with USB devices in the Linux or Windows world I wanted to ask the community what their experiences were.
Dan
06-25-2014 05:08 PM
Hi Dan,
I discussed this issue with some of our R&D engineers. Does this behavior reproduce with USB devices other than you USB to serial devices? For example, if you connect USB flash drives to the USB hub then remove one of the devices, do you lose connection to the USB flash drives?
Also, have you tried using this specific USB hub and devices with a LInux or Windows machine to check the behavior?
