01-21-2014 03:15 PM
The connection between the actual pins on the myDAQ and the long black screw connector that attaches to it is horrible. It is giving me inacurate results and variable voltages.
When I measure the +15V to AGND sometimes I get ~15 and most of the time I get 0.0V or something in between. It is highly untrustworthy. Is this a problem with NI?
-George
01-22-2014 06:07 PM
Hi George,
Are you able to read the correct voltage if you are measuring a known voltage source, such as a battery?
If your myDAQ is not functioning properly and you would like for NI to service the device, please contact National Instruments at (800) 433-3488 and ask for the RMA department.
Jordan G.
01-26-2014 07:58 AM
