04-03-2014 09:49 AM
04-03-2014 11:34 AM
Hey PadraicGranahan
Can you launch LabVIEW by itself without openeing a VI (from the start menu). Does LabVIEW Crash if you do this? If not can you create a new empty VI without LabVIEW crashing?
It sounds like the problem might be with the specific VI you're trying to open.
Can you also post a screen shot of the error you get when trying to open the VI?
Thanks!
-Sam K
Join / Follow the LabVIEW Hacker Group on google+
04-03-2014 11:48 AM
Hi Sammy, thankyou for the reply. Yes I can open Lab view on its own without it crashing. I have also tried a new blank VI on its own and it seems to work fine. Here is a screen shot.
Regards Padraic.
04-03-2014 11:52 AM - edited 04-03-2014 11:53 AM
Hey,
That error indicates that the VI you're trying to open is corrupt (it has an insane front panel object ). Where did you get the VI? Is there a link I can download it from?
Thanks!
-Sam K
04-03-2014 11:59 AM
04-04-2014 09:31 AM
If you start from a new VI and repeat the steps does the problem occur again?
Can you post a Max Technical report (instructions here)so we can see the versions of all the NI software you have installed.
Thanks!
-Sam K
