Hi!
I want to connect the Ettus Research USRP2 with my computer using the NI-USRP Utilities application.
But I encounter some promble, the NI-USRP Utilities application can't find the device.
I refer to the teaching of this web site. ( http://www.ni.com/pdf/manuals/375717a.pdf )
1. Installing the software:
Labview 2011
Labview Modulation Toolkit 4.3.2,
Labview Digital Filter Design Toolkit,
Labview MathScript RT Module,
and NI-USRP 1.0.
2. Default IP Address:
Host Ethernet Interface IP Address 192.168.10.1
Host Ethernet Interface Subnet Mask 255.255.255.0
Disable the firewall settings
The NI-USRP Configuration Utility can not find the USRP2.
And then I try to use the "uhd_find_devices" for finding the USRP2,
the result is:
C:\Program Files\National Instruments\NI-USRP\utilities>uhd_find_devices
Win32; Microsoft Visual C++ version 9.0; Boost_104400; UHD_003.002.003-vendor
No UHD Devices Found
Thank you!
