10-21-2013 08:24 PM - edited 10-21-2013 08:29 PM
I think it would be better if you have changed the driver to latest updated version. I am also not an expert in this. So, I may prouduce you with the best solution by consulting one of my friends having complete knowledge about this.
10-25-2013 01:02 AM
Ok, I am a little confuse with the pin output vs port output. I am assuming pin output = BNC 2090 while the port output is the output from the actual port shown in the data sheet. Therefore, if I am going to try to connect the LED directly to the Daq I will be using port output correct?
10-25-2013 03:47 PM
I'm a little confused as to what you mean when you're referencing port outputs and pin outputs.
You should be able to select a port on your device in NI MAX or LabVIEW. The name of this port corresponds to a certain pin on your device.
The pinout on the datasheet should list the pins and corresponding ports adjacent to each other.
Mike
10-25-2013 03:59 PM
Ok, in this image "http://forums.ni.com/ni/attachments/ni/10/2115/2/lin%20output.png" what does line output and port output mean?
10-28-2013 12:07 PM
A line is a single digital I/O while a port is multiple lines (i.e. lines 0-7).
10-28-2013 01:28 PM - edited 10-28-2013 01:29 PM
Ok, I thought 1 line = the controller for BNC 2090. So can anyone tell me how to use the software to use BNC 2090?
10-29-2013 03:03 PM
That is incorrect. When I drop down the line output tab there is port 0 to 7. However, when I drop down the port output tab there is only port 0.
10-30-2013 04:36 PM
Hey hunkeelin,
Someone asked a similar question in another thread on the forums. Here is the link to that thread.
