How to use myRIO webservices with an EDGE modem ?
I'm actually making a M2M system with myRIO.
I have an edge modem,  which communicates with myRIO by UART.
And I have a public IP.
Is it possible to use webservices of myRIO with the modem ?
Sorry but I am completly lost with UART, VISA VI etc...
Best regards
(5,896 Views)
Hey enzol,
LabVIEW Web Services only work through a valid network adapter (such as WIFI on myRIO) so you won't be able to use LabVIEW Web Services with a UART EDGE modem.
Let us know if you have any more questions about this.
Thanks!
-Sam K
LabVIEW Hacker
Join / Follow the LabVIEW Hacker Group on google+
(5,890 Views)
Thank you for your answer.
Is-it possible to install the modem with its drivers on the Linux RT and use it like a valid network adapter ?
(5,865 Views)
Hey enzol,
I assume this question is covered by your other thread here.
Depending on the hardware,  kernel modules and software required it may be easy to get the modem recognized as a network adapter by the OS, or very difficult (my guess is fairly difficult for this one).  If you're a Linux guru you can probably get it working.  If you have Linux quesitons you're best resource is the  NI Linux Real-Time community.
Good luck, and let us know if you get it working.
-Sam K
LabVIEW Hacker
(5,834 Views)
