04-23-2014 09:33 AM
I'm actually making a M2M system with myRIO.
I have an edge modem, which communicates with myRIO by UART.
And I have a public IP.
Is it possible to use webservices of myRIO with the modem ?
Sorry but I am completly lost with UART, VISA VI etc...
Best regards
04-23-2014 01:45 PM
Hey enzol,
LabVIEW Web Services only work through a valid network adapter (such as WIFI on myRIO) so you won't be able to use LabVIEW Web Services with a UART EDGE modem.
Let us know if you have any more questions about this.
Thanks!
-Sam K
Join / Follow the LabVIEW Hacker Group on google+
04-28-2014 02:05 AM
Thank you for your answer.
Is-it possible to install the modem with its drivers on the Linux RT and use it like a valid network adapter ?
04-30-2014 09:13 AM
Hey enzol,
I assume this question is covered by your other thread here.
Depending on the hardware, kernel modules and software required it may be easy to get the modem recognized as a network adapter by the OS, or very difficult (my guess is fairly difficult for this one). If you're a Linux guru you can probably get it working. If you have Linux quesitons you're best resource is the NI Linux Real-Time community.
Good luck, and let us know if you get it working.
-Sam K
