How to use audio input of mydaq to interface a sensor voltage acquisition
Hello Guys
I am using a NI myDAQ.
In my project I have to interface 4 MEMS pressure sensor whose output range is (0 to 1)V.
As there are only two AI channels in myDAQ (apart from DMM and Audio input). But I tried to use the stereo Audio input channels for acquiring data.
But it doesn't allow DC input and attenuates completely.
Is there any way I can use 4 channel input in myDAQ.
Any help is greatly appreciated...
Cheers,
Davidson D
(6,197 Views)
Accepted by topic author Davidson_D
Hey Davidson_D,
You should be able to read DC analog voltages using the Audio inputs.  Another option is to build a simple analog multiplexing circuit to switch between the inputs (for example you couldu use the 74HC4051).  You can control the mux using myDAQ digital outputs.
-Sam K
LabVIEW Hacker
Join / Follow the LabVIEW Hacker Group on google+
(6,190 Views)
Thanks Sam.
I tried with Audio input by giving in a sine wave ranging from 1hz to 100 hz. I observed that only above 20Hz i get approximately actual amplitude i sent.
Below that the signal is not correct.
Is there any settings for audio input?
The switching idea is good one. I will try to implement that in my project. 🙂
Davidson D
(6,185 Views)
