09-15-2016 08:21 PM
Is it even possible to set such an application to run on startup? If it is how would you go about doing it?
I compiled a program using the NI eclipse distribution and API and can run the program from Eclipse or by running it while SSH into the myRIO. The only documentation I could find relating to it is: http://digital.ni.com/public.nsf/websearch/B37FA04A1CB84B6C862571A30060EF03?opendocument&Submitted&&...
The link is a little outdated so I am not sure how relevant it is today. I changed the lines in lvrt.conf to:
RTTarget.ApplicationPath=/c/ni-rt/startup/startup.rtexe
RTTarget.LaunchAppAtBoot=True
None of the settings seem to do anything. I also tried launching the program like a script using rc.local which doesn't seem to be used the same way as it is in Ubuntu. My compiled pogram does not come with the extension .rtexe although I can add it later which might not be the same thing.
I made sure that the "disable startup programs" was unchecked on the myRIO webserver.
09-16-2016 04:35 PM
Hi neap,
You might have more luck posting on the NI Linux RT forum, since that's where questions related to the NI Eclipse distribution and API are generally answered.
09-16-2016 04:45 PM - edited 09-16-2016 04:50 PM
Thanks. There are so many forums.
09-19-2016 10:05 AM
