03-21-2013 10:23 AM
I have a PCI 6220 in my computer. I need it to generate a signal to a screw terminal block (ni TBX series). It needs to be a digital output with timing precision (minimum needed is microseconds). It then needs to send a signal to a stripped down harddrive that is just being used for a shutter with the arm moving back and forth. I start by using Output then the DAQ assistant but have trouble sending a signal after that. Does anyone know what I can do step by step to get a signal to be sent? Also, does anyone know of a preexisting program where I can check the delay time? Anything would be apperciated!
03-24-2013 05:35 PM
To see a detailed example of using digital output using the DAQ assistant click here.
Regards
