09-30-2013 07:28 AM - edited 09-30-2013 07:41 AM
Hi, can anyone answer my question?
1.How can i use the Labview front panel to view the results taken from the analog inputs of the Elvis II platform?
I will have 2 input waveforms which i will be using the waveform generator to create to transmit to the analog inputs.
Then i will need to view the inputs using Labview which i cannot seem to do.
2. I also cannot use the waveform editer in the Waveform Generator in Labview front panel.
3. And is there any way i can view the output waveform from the Waveform Generator on labview? I searched and only found function Measurement I/P.
10-01-2013 02:38 AM
You must connect analog output to analog input in order to view it. You can find analog input example from LabVIEW Help>>FInd Examples>>Hardware Input and Output>>DAQmx>>Analog Measurements>>Voltage>>Acq&Graph Voltage-Int Clk.vi.
10-01-2013 11:12 AM
Hi, thank you for your reply.
I am using an Elvis board, but i still have to use DAQ to acquire the analog inputs?
I will require the use of analog inputs to receive signals, however, i also need the analog outputs to transmit signals.
Actually i already used the analog outputs to connect them to the analog inputs as i used the waveform generator to generate the waveforms, because i require at least 2 waveforms so i could not use the function generator.
But i am wondering how i could use the analog outputs to transmit signals and still be able to use them to generate waves with the waveform generator?
Hope to hear from you soon.
Thank you.
