06-07-2016 10:39 AM
I started on a My Rio 1900 which I am trying to program in C language, so without using Labview.
I managed to sample a signal.
But I wish to sample it at a higher frequency than is possible with standard FPGA Personality provided by default.
The doc of My RIO says that it requires the High Throughput FPGA Personality.
I downloaded it on ni.com but its installation requires Labview 2014 ...
So my questions are :
How can I do to work with the High Throughput FPGA Personality in C Language and how can I install it without Labview ?
Thank you in advance for your help
Best regards
Françoise
06-08-2016 10:46 AM - last edited on 01-04-2024 05:38 PM by migration-bot
Hello fm16,
NI High Throughput FPGA personalit
2) https://www.ni.com/en/support/documentation/supplemental/15/ni-high-throughput-add-on-for-myrio.html
to use High Throughput FPGA personalit
Dasso
06-08-2016 03:04 PM
thank you for your answer even if it is not very nice for me !! 😞
Best regards
Françoise
