07-25-2017 08:37 AM
HI All,
I have already put my file fuzzy.fs to MyRio, I get error code from Fuzzy Load is Err7, My Fuzzy Toolkit not work, How to solve this problem?
Thank You,
Solved! Go to Solution.
07-26-2017 09:23 AM
Error 7 is a file permissions error. The file probably isn't on the myRIO when your application on the target is running and therefore LabVIEW can't find it. When using a myRIO, you are basically using another computer (the RT OS on the myRIO itself) to run the VI's that are under the myRIO.
I know you mentioned that it is already on the myRIO but how did you add it to the target? From the picture you gave it still looks like it has a Windows file extension.
Try this KB to transfer the file onto the myRIO and then change the directory constant to the new file location.
-Bear
07-26-2017 06:58 PM
Thanks Mr Bear its Work
