Good evening
I am completing the tutorial about NIeval quit of CompactRIO.
I am using a RIO 9631 and after compiling the 1st example(simple counter example)
I get this error:
"you cannot run this VI because the because the target resource does not match the actual type of device"
I go to project and I see than FPGA resouerce is RIO0, the same that is by default in the project, the same is in the tutorial guide and the same appears in MAX.
I have to say I had installed the Labview before testing the card so I only have copied the folder of the tutorials in my desktop and I have opened from there.
Can u help to solve this error??
