07-06-2014 10:26 AM
Hello, I've recently won the myRIO, but when I try to install it, I get this error and it says that some software could not be found, also myRIO Status LED is blinking twice every few seconds.
Solved! Go to Solution.
07-08-2014 08:50 AM
Dranoel,
According the myRIO manual ( http://www.ni.com/pdf/manuals/376047a.pdf ) if the LED is blinking twice it means that the device has detected an error in its software. You need to reinstall software on the device.
For that you can follow the instructions on the link below for that:
http://zone.ni.com/reference/en-XX/help/373925A-01/myriohelp/myrio_advanced_config/
The recomended software to install in your myRIO is the LabVIEW 2013 myRIO Module f1 Patch, here is the link for the download:
http://www.ni.com/download/labview-myrio-toolkit-2013/4469/en/
After some research i found that this patch fix that specific issue ( http://digital.ni.com/public.nsf/allkb/437F6538BE9B301486257C0C0075FD18?OpenDocument ).
After installing this patch use the NI Update Service to make sure the software is updated. Only after the necessary updates I recommend following the steps in the first link.
I hope this will resolve your problem, just let me know if it worked,
Best regards!
here is my reply in portuguese:
Dranoel,
De acordo com o manual myRIO ( http://www.ni.com/pdf/manuals/376047a.pdf ) se o LED está piscando duas vezes, significa que o dispositivo detectou um erro em seu software. Você precisará reinstalar o software no dispositivo.
Para isso você pode seguir as instruções no link abaixo:
O software recomendado para instalar no seu myRIO é o LabVIEW 2013 Myrio Módulo f1 Patch, aqui está o link para o download:
Depois de algumas pesquisas eu achei que esse patch corrigir esse problema específico (http://digital.ni.com/public.nsf/allkb/437F6538BE9B301486257C0C0075FD18?OpenDocument)
Depois de instalar esse patch utilize o NI Update Service para ter certeza que os softwares estão atualizados. Somente após as atualizações necessárias eu recomendo seguir os passos do primeiro link.
Espero que isso irá resolver o seu problema, é só me avise se funcionou.
Abraço!
07-09-2014 12:08 PM
Thanks a lot. It's working now!
07-10-2014 06:48 AM
No problem !
04-17-2016 11:04 PM
actually i am also got the problem as mention above by dranoel. but it still can't be solved even if i follow the solution given in the 2nd link given by you. yet, i got another error on NI MAX as attached. can you please advice what actually happen
