06-29-2012 04:09 AM
Hi eveybody
I am currently using a ATX4K-7 (AEROPROBE) computer, but I'm looking for making a connection between the CPU given by Aeroprobe and DAQ from LabVIEW.
This CPU is used to sense 7-hole pressure probe. And I want to use LabVIEW and DAQ to get speed plots
However, when I try to find a driver to install in LabVIEW, the different choices does not include Aeroprobe (or Althen).
Could someone give me the choices to do, so I can find the right driver to download? or is there a driver that can be used for several CPU.
Thank you in advance
Kind regards
06-29-2012 10:12 AM - edited 06-29-2012 10:13 AM
Check with the vendor to see what they might have. Otherwise, you will need specs on the communication interface and then write your own driver.
p.s. How is this related to NI Academic products or did you post to the wrong board?
