Hi Alex,
If you're trying to correct logic problems in your code, you might try turning on highlight execution to see how the boolean data is actually moving through the code. You should read about execution highlighting here.
You might also watch the tutorial on execution structures found here.
Let us know if you still can't figure it out!
Andy C.
Applications Engineering
