I'm a new Labview user and am trying to acquire some data from some force sensors connected to a NI USB-6009 DAQ.
After installing the drivers, I tried plugging the force sensor in to the DAQ (I'm using a Flexiforce force sensor). The ground is in to the GND plug, the positive and negative are wired to the AI0 and AI4 screw plugs.
I placed a "DAQ Assistant" block on a new VI and tried to configure it for a Force Sensor. Unfortunately, the DAQ Assistant is saying that there are "No supported devices found" (Acquire Signals -> Analog Input -> Force -> ). I checked in the Measurement and Automation Explored and the DAQ is recognized/ listed there.
I would appreciate any suggestions and help. Thank you.
