11-25-2013 11:55 PM
Here's my try. It does't do what I want though, but why?
11-25-2013 11:55 PM - edited 11-25-2013 11:55 PM
dup post.
11-26-2013 03:01 AM
Apart from the 2nd wait not fitting your earlier description and the you should have a small wait in the read-loop (and the extra error wire) it should work. Try running it in Highlight- and Retain wire values-mode. Maybe you're checking the wrong input/outputs? Port 0 isn't at pin 0.
/Y
11-26-2013 07:11 AM
Your problem description is sorely lacking. Just saying that it does no do what you want is less than descriptive. Does it not exit the loop, not turn on the LED, blow up?
